*88 89 90 91 ECU Codes - 1funryd *
How to change a Timing Belt for the B20a5 and B21a1 Motors <---- Click Here
I felt with all the aftermarket that is up and coming and with some of the old info being revisited, that I should organize all of them into one useable thread. I will update this as necessary.
So, this should be useful to all us 3rd geners, hopefully we can get it sticked.
Sean
The only Companies that support the 3rd Gen community are:
1. www.1funryd.com(Me) - Engine swap mounts
2. www.lsdmotorsports.com - Turbo kits & parts, Flywheel, custom intake, custom exhaust, upraded clutches.
3. DIY - Exhaust for 88-91 Preludes
No longer available only for reference
LSD CAT-Back Exhaust - Completed!! (
1 2 3 ... Last Page)
1funryd
4. www.TEIN.com - Super Pro Suspension Bushings
5. ****
7. www.summitracing.com - for miscellaneous parts such as aftermarkt headers, catbacks, msd ignitions, etc..
8. www.fastbrakes.com - For Big Brake Upgrade with Wilwood Calipers and steel braided brake lines
9. www.raceeng.com - After market pistons and internal engine parts.
10. http://in.teamprototype.com/?nav=estore&cat_id=4&scat_id=14&no_splash=1 - Teamprototype for Carbon Fiber parts and accessories Specifically for our 3rd Gens.
11. Best site for 3rd gens ever: http://www.prelude3g.com/
12. Specialty Tools for the 3rd:
3rd gen Tools Oddballs and large
cudaboy
13. Conversion Harness for OBD0 to OBD1 for turbo charging or tuning
14. Tailored Prelude Floor Mats w/logo - http://www.dstuning.com/88_91_honda_prelude_floor_mats.asp
15. 4WS Alignment Tool - 4ws Alignment Tool
16. Auto to Manual Swap -
Auto to manual (5 speed) swap writeup UPDATED - pics added back to first post (
Daily Interlude
**Engine weight Comparisons -
Suspension Bushing Upgrade Thread:
The End All Polyurethane Bushing Thread!!!
cudaboy
Engine Mounts Aftermarket:
1FunRyd:
New - 1FunRyd Performance - design for H22 kit (current):
Or pm me at: 1funryd
Thermal Stainless Steel 2.25" Catback - $450 + shipping (Current Group Buy Going) Here: Thermal R&D-2.25" Stainless Steel CatBack Group Buy (
1funryd
--3rd Gen Body Kit FAQ's--
1. H22 Mounts - 2nd H22 motor mount Group Buy??? - by www.1funryd.com
Related info on mounts -
a. AZ Race H22 3g Mounts Review
b. H22 Swap from Honda-Tech Write-Up*
c. Long H22 Swap Write-upH22 Vtec SWAP conversion WRITE uP; An Introduction. Long.
d. H22 Write upHugeDomains.com - TeamInterlude.com is for sale (Team Interlude)
e. Dyno Power on a Base H22 Swap - 1991 H22 Dyno Run
f. H22 Track Run on Base H22 - 1991 H22 Track Time: Numbers Inside
g. B20Lluda's - H22a dyno and pics...
h. Axle info on H22 conversion - FINAL WORD ON THE 3rd H22 swap axles...
i. AZ Mounts w/Powersteering - AZ H22 Mounts w/Powersteering -
j. Possible H22 Swap Problems with the AZ Race mounts (Actually a damage frame)
k. teams ranfla (H22 start up video on page 4)
l. 1991 H22 Track Time: Numbers Inside
m. H22 third Gen Time Slip: 14.7
n. More: 1991 H22 Track Times - Slips inside
o. H22 Engine Weight:
p. HELP A/C & P/S in 3rd gen w/H22 swap
q. Wiring for the H22 Swap - Rywire Harness(No longer valid since Rywire changed their support)
r. H/F Series Motor specs for the Engine swapper
s. Questions regarding OBDII motors for the H22 swaps - obd2 h22a info pls
2. Wilwood - 3rd gen Big Brake kit, now available..!!!!!!
3. Aftermarket Steering-Wheel Hub w/Cruise - Group Buy for steering wheel hub with Cruise buttons
a. HKB Steering Wheel Hub
4. B21A1 Rebuild w/pics - B21A & Suspension Rebuild Progess
Related info to engine rebuild on the B21A1:
a. Timing Belt Installation
b. B21 and B20 Injector differences
5. 3rd Gens - OBD1 Conversion for Tuning and Fuel Management
a. How-To: Honda OBD1 ECU Chipping
b. Turbo charging an automatic 88-91 prelude - I am turboing an auto. Has this been done by anyone?
6. B16 Conversion on B20a5 Block Ludespeed-writeup
7. 4th gen caliper upgrade pics
8. Strut Bars designed by MustardCat - MUSTARDCAT STB (reproduction) --- GROUP BUY ---
9. ACS: DigiTach Group Buy!!
10. B20A3 to B20A5 engine swap write up
11. Cold Air Intake(Simple) - Write Up!!
13. Tickin sound under Valve Cover
14. Write up: Blue Backlight for Gauges
**15. B18C5 Swap into a 3rd gen Lude - Beginning of a cool swapBeginning of a cool swap
16. 3rd Gen_ N/A Build B20A5 (W/Dyno Results posted...lots of Pics)
17. OBD1 Conversion People, I got a Questions??
18. K20 in a 3g lude w/pics
19. AutoCad pics of how a K will sit in our chassis: - K-series mount thoughts
20. Custom Bumper mod - Tommy's Prelude part 1 -lots of pcs
21. PowerSteering Oil Seal Replacement Write-Up
22. B20-VTEC Conversion Repost
23. THE OIL PUMP SEAL INSTALL THREAD (pics)
24. Group Buy for AZ RACE B20A/21 Mounts
25. Feeler for S&S Header Group Buy
26. SECLUDED PERFORMANCE ADJUSTABLE ENDLINK prototype is made. Sign up here for the GB
27. Filled Motor mounts
28. who wants a b18 intake cam? group buy... (never completed)
29. EXACT Stock 3g and b18 Camshaft Specifications
30. Compression test results on B21 block with B20 head...
31. 89 si auto, overdrive only when under load
32. HOW-TO: Convert Your Dual O2 Sensor Set-up To Single O2 Sensor
33. 1Funryd's - PowerSteering - ReRoute and Replacement
34. How to: Improve PS feel and maintainance
35. CADster's - sweet P/S line reroute how-to (56k frendly)
36. How I cleaned my EGR ports..pics
37. Budget custom cut floor mats, matching molded carpet +
38. Replacing Radiator Fan??
39. A/C Compressor Contol Unit & Fan Resistor
40. Front Lower Control Arm Ball Joint Write-Up
41. Axle Removal write-up
42. What You can do to your B20a5
43. Direct Swap for 5th gear from accord... for higher speed & lower rpm
a. Shortened Gearbox
b. H2A5 Gearset Swap
44. Information for Cams, Runner length diameter
45. LED Conversion Write-up
46. Mishimoto 1/2 rad
47. My SuperPro Bushings, Sway Bar, and (Seized) Strut Install
48. Front Endlink Replacement - Write Up
49. 1st Ksport Group Buy - Feeler for Coil Over System
50. C-Pillar bar ebay alternative
51. Engine Hesitation - Check List
52. Differences between Series engines: - F><H series?
53. Yellow Fog Light Write-up
54. C-Pillar Bar: Em Racing Official Group Buy Thread!
55. Individual Throttle Bodies for the B20A
56. Throttle Body Upgrade - WRITE UP!!! Integra Type R TB install (B21)
57. Upgrade Hangers - Blue Polyurethane Exhaust Hangers!
58. 3rd Gen Weight - 3rd Gen official weight thread started by Afterburners
59. Alternator Upgrade This also works with the H23 alterntor - 94 accord alternator
60. Seat Brackets for Aftermarket Seats - FINALLY...my mail-order BRIDE arrived!
61. Saggy Door Write up - Saggy Doors Fix! Write-up Inside! (pics)
62. Fix for 90-91 VSS Speedometer - Speedometer Issue.
63. LSD for our B20/21 Transmissions - LSD impressions / HOW TO!! - MustardCats link
64. Guessman's Wiring(Interior & Engine) Write-up with Plenty Pictures - SI wire harness photos whanted!
65. Lower Control Arm Bushing Replacement(Prothane) - My lower control arm bushing install
66. TPS Sensor Information - Brand new tps sensors, without buying complete Throttle Body
67. Replacing Lower Ball Joints - Possible write-up (with pics) for front lower ball joints? (Search is down)
68. Another LSD Thread - New option for 3dGen LSD...read on
69. How to Remove Tuner Lug Nuts & Regular ones as well - stripped socket lug/tuner lug
70. Accord gears
71.Differences between Clutch Kits for 88/89 - 90-91 - Serious wrong clutch for the car....tranny/engine/flywheel identification help.
72. Cylinder Sensor Leak - Fix by Cudaboy
73. How-To: Replace Brake Master Cylinder
74. Red A/C Light DIY info - Red light on a/c switch
75. Dash Light LED Upgrade - Write up: Blue Backlight for Gauges
76. Motor Swaps - Thread...
77. Third Generation Prelude S (carburated)Performance Inventory!
78. Timing Belt Installation
79. Aftermarket Valve Springs
80. Clear Corners - 88-89 Prelude
81. B20a 3rd gen Prelude website in Japanese - 56k WARNING!
82. NA built B20a5 Result - getting dyno'd finally...
83. Integra Digital Cluster swap
84. B21a1 to B20a5/A Swap - Write up
85. Auto Trans to Manual Swap Guide
86. Overheating issue - Pinhole in Headgasket??
87. Another Aftermarket Flywheel - After Market Flywheel - aascomotorsports
88. Integra LS Distributor swap - LS distributor fits B21
89. Main Relay - Other Honda Replacements
90. Transmission Gear swap - Accord 90-93
91. Swapping from 88-89 Gauge Cluster to the 90-91 Cluster.
92. Aftermarket 2ws Rear Toe Arms
93. B18 cam modification to fit b20a5
94. Bouncing Idle Fix
95. Relocating the engine bay fuse box
96.UCA bushes, the myth, the theory, the truth..
97. 88-91 Prelude - Rear Ball Joint Part#
98.Center caps - (alternatives)
99. A/C Compressor Control Repair - (BrianK from NSXPrime - Email: briank@nsxe-repair.com)
100. JDM Climate Control Pinouts
101. ALB Pump Replacements alternative - NSX
102. Upper Control Arm Bushings - Prothane Part# PTP 8-205 or 8-213
103. 88-91 Prelude - Big Brake Upgrade - 92-96 Prelude vtec 11.0" Rotors
104. 1FunRyd 88-91 Prelude Front Lip
105. Auto Transmission Solenoid maintenance DIY procedure
106. Center Caps Options
107. Ksport install and feedback
108. B20a5 vs. H22a
109. 4WS Locking Tool
110. 88-91 Honda Prelude - Molding clips Front windshield molding
111. 3rd Gen_ 4ws Ryan Starts Fresh. New build thread.
112. B20a5 with B18 pistons and h23 rods
113. ReyKe's fitting of B18c5 pistons onto B20a5 rods
114. 1FunRyd - 88-91 Prelude B20vtec swap
115. 1FunRyd - 3rd gen Rear Roof Visor - Group Buy
116. NRG Wheel Hubs - Quick Release
117. 88-89 to 90-91 Tail light conversion
118. HKS Steering wheel hub with cruise control button's
119. Cooling System, Radiator Fan - Troublshooting
120. ARP Head Stud kit - B20a5/B21a1
121. 90-91 to 88-89 Front bumper swap and wiring write up
122. 88-91 Prelude 3D Printed clock cover, gas cap and holder, glove box handle
123. 90 91 Prelude VSS Sensor Replacement option
124. 1FunRyd - SeatBelt Constant Torque Springs - 88-91 Honda Prelude
125. B20/21 - Timing Belt and Water Pump Replacement
126. 1988-91 Prelude Front Hub Replacements
127. Custom Prelude Embroidered Mat
128. Removal of 90-91 Gauge Cluster
129. Write-Up: JDM Power-Folding Mirrors Install.
130. Rebuilding B20/21 Oil pumps
131. Rear 2WS Toe Arms - Aftermarket 2ws Rear Toe Arms
132. Cometic MLS HeadGasket Original Project
133. Cudaboy's Trim Clips Door Bumper Glass Moulding Molding & Screw Grommets
134. CAM Positioning Sensor Seal Replacement
135. 4WS Rear alignment Tool
136. 88-91 Prelude - Rear wheel Bearing replacement and Sunrood Glass removal(MustardCat video)
137. 88-91 Prelude - Fuel pump replacement(MustardCat video)
138. 88-91 Honda Prelude - Automatic to Manual 5 speed swap(MustardCat video)
139. 88-91 Prelude - Front and Rear Brake replacement and maintenance(MustardCat video)
140. 88-91 Prelude - Disconnecting of Ball Joints: Upper, Tie Rod, Lower Ball Joints(MustardCat video)
141. 88-91 Prelude - B20A/a5 and B21a1/A intake and exhaust valve sizes
142. 88-89 to 90-91 Gauge Cluster swap. - 88-89 prelude to 90-91 prelude Gauge cluster swap
143. 88-91 Prelude 4WS Rod Ends - Replacement - 4WS Rear Tie Rod Replacements
144. 88-91 Prelude - Turn signal issue - Abnormal right side turn signal
145. 90-91 Prelude - DIY ABS Bypass - video
146. 88-91 Prelude - Proper Idle and ignition adjustment Procedure
147. 88-91 Prelude - AC Compressor Conversion - DIY 88-91 Prelude
148. 88-91 Prelude - Coolant Temperature Sensor
149. 88-91 Prelude - 95 Acura GS Legend 2 Pot Big Brake Upgrade
Headers:
I spoke to Marty this morning(3/28/08), and he informed me that the power rating on any axle is going to depend on the geometry of your suspsension, example:
How to post up pictures you want show:
Sean
1funryd
5. ****
cudaboy
cudaboy
1FunRyd:
H22 Billet Swap Kit * No longer available in billet *
B20/21 Mounts
- Billet H22 Swap kit - $475
- Billet B20/21 stock replacement - $350
- Traction Bar - $400 (Group Buy going on now)
- All prices due not reflect shipping or paypal fees
You are able to purchase thru me contact info below:
- Sean Tydingco - www.1FunRyd.com
- Email: 1funryd@comcast.net
- Cell: (206)304-4095
- Or pm me at: 1funryd
- Steel Welded - $199.99
- You must go to www.innovativemounts.com to purchase
B20/21 Steel Welded Mounts
Updated Suspension:
Ksport Kontrol Pro Kit - $820 shipped in the US, Canadianand other international shipping quoted only(Edit: KsportUSA prices are subject to change due to cost increases or decreases.)
Updated Suspension:
- 36 way adjustable strut dampening
- 0" - 3" Ride height adjustablility
- T6061 Aluminum body
- 1 year warranty
- The best suspension for all 3rd gens!!
Cell: (206)304-4095
1funryd
- Contact Michael Succar and tell him Sean Tydingco sent you at:
- 1-877-573-6686
All Honda ECU Codes (<--- clik here)
1funryd
The only 3rd gen that has stated to be 200hp N/A:
Hitomi88 - JDM 88 Prelude
Performance Upgrades Old and New:
1funryd
H22 Swap Info Section
- Original source thread: Cold Air Intake without battery relocation and writeup
70. Accord gears
108. B20a5 vs. H22a
Exhaust Starter Information:
Headers:
- Hedam - Chikara & Torque Step models. Flex pipe design(most popular, but make sure to torque it down correctly or will blow gasket)
- Pacesetter - Pacsetter model - Ball joint design for connection(not very liked)
- DC - No longer produced and according to them, they will not reproduce anymore.
- 7Street & Strip Headers(S&S Headers) - Only for 90-91 models but they fit all 88-91 Preludes, just need to convert to the single O@ sensor(there is a writeup in the Sticky's-FAQ's)
CATback:
- LSDmotorsports.com - Custom mandrel Bent Stainless Steel w/ 2.25" (very quiet design and is the best in my opinion) ask for Mike Succar and tell them Sean sent you.
- Thermal R&D Exhaust - 2.25" very similair to the LSD catback but with a different muffler. **Note must be ordered thru an authorized dealer.
- Pacsetter Catback -2.25" mandrel bent as well with black paint finish that will burn off and is made out of mild steel. Best bang for the buck for low budget catback upgrade.
- Magnoflow
- Pacsetter
- OEM
- Universal aftermarket - must be welded with proper flanges and hanger from a professionl exhaust shop or DIY'er.
Websites to start at:
www.summitracing.com- pacesetter, magnaflow, hedman-chikara etc...
www.ssheaders.com - S&S Headers site
AfterMarket Axle Information:
- How lowered is the car
- What size diameter tires
- Street tires
- Sticky tires
- Slicks
- H22: $174 per axle
- B20/B21 200-250hp: $174 per axle
- The next step up for higher horsepower: $219.00 per axle
He is a very nice guy, just give him a call and let him know what you have done to your car how low are you and what type of tires you normally run them on and so forth.
Be as clear as possible so there is no confusion when ordering.
Sean
www.Raxles.com(ask for Marty)
(888) 257-8192 or (800) 257-8192
8:00am - 6:00 pm Monday thru Friday
Sean
1. Go to https://imgur.com/ and register(its free)
2. Upload your pictures. Once your photos are uploaded, just clik on the photo you want to link to your post or thread. Make sure to keep the thread open in a separate window so you will be able to "copy & paste" to your post reply.
3. On the upper right corner of the window you will see your username, click on it and then select images. This will take you to your gallary and then select the picture you want to insert.
4.Select "your pictuer and then a sub window will popup and then the links to use for posting on preludepower will be on the right side."
5. Click on "Direct link"(URL) example:
https://i.imgur.com/EWJl6bm.jpg
6. Right clik on the highlighted Address(URL) and clik "copy"
7. Now go back to the Post Reply window and clik on the "Insert Image" icon will look like this below.
8. Now just erase whatever is in the address bar, and right clik in the address bar and paste the (URL)Address into the address bar, and clik "OK"
9. Your picutre will be linked to your post. Now just repeat the process for anymore pictures you want to link.
Now hurry up and show us what you are talking about. We like pictures!!!?
Sean
Sean
