Go Back   Preludepower.com > Prelude Forums > Builds
Reload this Page 3rd Gen_ Toxxicluder90's new build thread... 91 4ws. start date: 9/12/07
View Poll Results: Trade my kosei's for the brand new Work Emotion replicas and tires.?
FO SHO!!! 30 50.85%
no way... 29 49.15%
Voters: 59. You may not vote on this poll
Reply
Ads By Google
Thread Tools Display Modes
Old 10-30-2007, 12:25 AM   #251
Nu2Ludes
Newbie
Nu2Ludes's Avatar
Nu2Ludes is on a distinguished road
i've had that happen, or at least similar on several cars, the solutions to the problems that i've come across: bump in the tire, wheel bent or outta balance, cotter pins werent installed on the front axel bolts and things came loose(not good..but not "not good" like the wheel fly off while ur driving on the highway, but "not good" as in ur car breaks down in the middle of an intersection and you have a suspended license and ur dog in the back seat...end up in jail... gg cotter pins) heh sorry for side track, but anyways those were the solutions to my issue they may or may not be the one for yours.
heh my bad, replying to old post, sorry you can delete
Nu2Ludes is offline   Reply With Quote
Old 10-30-2007, 12:54 AM   #252
ToxxicLuder90
Preludepower Member
ToxxicLuder90's Avatar
ToxxicLuder90 will become famous soon enoughToxxicLuder90 will become famous soon enough
Send a message via AIM to ToxxicLuder90
Prelude of the Month
Originally Posted by ludakiss View Post
badass vids, how fast were you going as you were passing by in the 3rd video?
i think i was only doing like 60-70. As you can tell, i wasnt really on it.
I was trying to not piss off my neighbors as much as possible.
that was also with my old exhaust.
One of these days i'll go and get similar videos to compare exhaust sound w/ the new Thermal. & i promise i'll go a bit faster in the next take.
Check out this new compilation i just got done making.
http://videos.streetfire.net/video/2...d700313ac2.htm
__________________
-Brett-
91 Si 4ws-
97 SH ATTS-
ToxxicLuder90 is offline   Reply With Quote
Old 10-30-2007, 05:47 PM   #253
dankvilla
Donating Member
dankvilla's Avatar
dankvilla is on a distinguished road
I just bought a white 91 Si 4ws in excellent shape other than the blown b21a1 4 $500,what a steal pics 2 come!I'm really excited about becoming a member of the 3rd gen family but have heard and read so many bad things about the b21a1,can someone please tell me something good about it I'm goin to PA tommorow 2 pick up a low mileage replacement block for $250!temporary while saving the money for h22 swap already ordered mounts from azracemachine!
dankvilla is offline   Reply With Quote
Old 10-30-2007, 08:01 PM   #254
ToxxicLuder90
Preludepower Member
the only good thing about it is that ni good condition that motor has more power than the other usdm b20's
__________________
-Brett-
91 Si 4ws-
97 SH ATTS-
Old 10-31-2007, 06:44 AM   #255
Rambothemighty1
3>*
Rambothemighty1 will become famous soon enough
Send a message via AIM to Rambothemighty1
Man, I think danky over there was thread jacking
I like the thermal on your car, it's loud but it's nice.
WHAT IS NEXT?!
__________________
Okay newbs, lisa is right...
Rambothemighty1 is offline   Reply With Quote
Old 10-31-2007, 06:57 AM   #256
m1k30rz
JDM fo lyf y0
m1k30rz's Avatar
m1k30rz is on a distinguished road
Send a message via MSN to m1k30rz
When you jumpstarted that with the neg on the radiator and the pos on the dist block it woulda basically just started the car off your jumper pack and let the alternator run the car which obviously doesnt have enough juice to run both ur cd player etc AND your engine.
Would just be a shortcut way of starting the car. Means your battery wouldnt have done anything you may as well not have even had the battery in your car at all by starting it that way lol. Id say your wire is damaged somehow.
__________________
JDM 1990 Honda Prelude SiStates - B21A - 5 Speed!!
m1k30rz is offline   Reply With Quote
Old 10-31-2007, 01:18 PM   #257
ToxxicLuder90
Preludepower Member
Yeah i knew it was basically skipping the batt. all togeather.
& i guess something has to be wrong with the wire, its so reciulous though. Its a solid wire all the way to the trunk. Only thing i could think of is that maybe it got damaged from the fender being smashed in when the cart hit it and maybe it is rubbing against something & worn through. A short perhaps?
i dunno, im no wiring guru... so your guess is as good as mine.
I have off tomarrow or fri. so i'll be tearing it apart to try and figure out wtf is wrong.
__________________
-Brett-
91 Si 4ws-
97 SH ATTS-
Old 10-31-2007, 08:28 PM   #258
ToxxicLuder90
Preludepower Member
WHAT IS NEXT?!
he was indeed...very random.
but yeah the next thing to happen is the fixing of my lude. Somabitch wont start. So i need to rip out the power cable to inspect it for tears or breaks in it cuz its def. not transferring the charge from the batt. to the fuse box for some reason.
After that, shes getting garaged.
Things to do:
1) Winter is approaching and the engines in need of upkeep. I.e. numerous gaskets, moving some wires, re-wrapping other wires.
2) Exchange the broken antenna motor and antenna out with my spair.
3) Complete A/c removal, seeing how the guy before me felt it was necessary to remove just one of the lines from the compressor to the firewall & left everything else in there (compressor, condenser & such)
4) trying to find a used Half rad. maybe a PWR.
5) Getting rid of or relocating the windshield washer fluid reservoir.
6) Finish the Black interior swap by swapping the tan door panels out & black ones in. Requires some modifications to add the power lock switches, since the black panels dont have it.
7) Special fabrication projects. Its gonna be a suprise mostly. Fiberglassing some things i've been thinking about for the dash. Seeing how i have a spair dash to Fook~ around with.
8 ) Possibly finishing my door pod that i was working on, on my yellow lude a while back. Would also be easier to do now that i have spair door panels.
9) New p/s fluid reservoir & lines...
10) New vacume lines...
11) Should be the first thing on the list... but i desperatly need to fix the idle issue.
12) Air duct project.... kinda iffy on direction im going with it, its basically just an "if i really have the time" kinda project.
13) All new ball joints all around, 4ws tie rod end links i think needed replaced.
14) Possibly purchasing the Orijin Bushings upgrades.
15) **new tailight seals...mine leak like a mofo.
16) False floor w/ full size spair.
17) I have a few spair b20 heads laying around and one has a Painted intake manifold attached that actually looks quite nice. Im thinking about installing that one onto my motor. No reason really besides the fact that i like the way it looks. ( 2- B20a's & a B20b (crv) head to be exact)
18 ) find a nice steering wheel & install my HKB quick release hub.
theres prolly a lot more i need to do but thats all i can think of for now.
__________________
-Brett-
91 Si 4ws-
97 SH ATTS-
Old 10-31-2007, 08:37 PM   #259
Rambothemighty1
3>*
that's a pretty hefty list as is anyway, it should keep you busy
__________________
Old 10-31-2007, 08:42 PM   #260
ToxxicLuder90
Preludepower Member
I got nothing but time.
It also helps not having friends around here... no distractions...although theres no one to help.
Makes it easier for things to get done not having to rely on it as a DD.
__________________
-Brett-
91 Si 4ws-
97 SH ATTS-
Old 10-31-2007, 08:43 PM   #261
Rambothemighty1
3>*
VERY true to that last part
My friends wouldn't know how to help even if I did let any of them touch my car
__________________
Old 10-31-2007, 08:46 PM   #262
chromalux
Donating Member
chromalux's Avatar
chromalux is on a distinguished road
Send a message via AIM to chromalux
u luck sob, having a winter vehicle and getting to play around with it all winter
__________________
No no keep redlining it, b21's love that shit.... FUCK
chromalux is offline   Reply With Quote
Old 10-31-2007, 08:48 PM   #263
chromalux
Donating Member
chromalux's Avatar
true dat, last time i let a friend touch my car, my s10 never started again, and the time before that MAGICAL electrical problems show up RIGHT after he starts touching it. now i don't let anyone touch my car unless ur ase certified, then you can pay me to practice on it
__________________
Old 10-31-2007, 08:51 PM   #264
ToxxicLuder90
Preludepower Member
and then guess what... either late this winter or this comming spring the Jeeps getting its own treatment. how soon depends on how i keep to my savings promise to myself. I'm putting away little by little for how shall i say...a rainy day.
4.5" lift kit, and some 32" tires.
oh yeah, jealousy is a sweet bitch.
__________________
-Brett-
91 Si 4ws-
97 SH ATTS-
Old 10-31-2007, 09:04 PM   #265
chromalux
Donating Member
chromalux's Avatar
just wait till you see the w. third street paint job, it's starting to come along just need to get the rest of the parts i need. and i'll be getting some other fun stuff for over xmas break b4 i get the license back. man i can't wait to legally drive this thing again and get to play with it
__________________
Old 10-31-2007, 09:51 PM   #266
RedLuder89
Preludepower Member
RedLuder89's Avatar
RedLuder89 is on a distinguished road
Send a message via AIM to RedLuder89
I know this might me pushin it but what r ur plans performance wise?
Turbo,all-motor,h22 swapped?Just kinda curious
RedLuder89 is offline   Reply With Quote
Old 11-01-2007, 04:01 AM   #267
ToxxicLuder90
Preludepower Member
h22 swap eventually.
prolly tackling it next winter or next fall & gathering the parts for it all summer.
__________________
-Brett-
91 Si 4ws-
97 SH ATTS-
Old 11-01-2007, 06:04 AM   #268
Kamakasi
PrElUdE4LyFe's Big Bro
Kamakasi's Avatar
Kamakasi is on a distinguished road
Send a message via AIM to Kamakasi
kinda looks like a hillybilly missing a tooth looking good though toxxic
__________________
B20a5 Si Block replacement and mild
tuck project - (Pics page 3 - Updated 3/4/09)
Updated 4-05-09
Parts for Sale
Full set *Mint* Taillights - 30 + SH
DS and PS Corner/Turning Lights - 15 + SH
a5 Valve Cover - 20 + SH
90-91 ECU - 15 + SH
Kamakasi is offline   Reply With Quote
Old 11-01-2007, 08:50 AM   #269
danny_d19
Fuuuuuuuuuuuuuuuuu
danny_d19's Avatar
danny_d19 is just really nicedanny_d19 is just really nicedanny_d19 is just really nicedanny_d19 is just really nicedanny_d19 is just really nice
"Spare"
lol
Are you moving the battery box if you're putting a spare tire back in the trunk?
__________________
danny_d19 is offline   Reply With Quote
Old 11-01-2007, 09:39 AM   #270
Hondamonster
toguetastic
Hondamonster's Avatar
Hondamonster is on a distinguished road
Originally Posted by danny_d19 View Post
"Spare"
lol
hey, spares are all the rage! just get the orange jdm ones from the internets lol.
really though, dont blow a tire without a spare.
i <3 spares.
__________________
プレリュード Honda Prelude
Hondamonster is offline   Reply With Quote
Old 11-01-2007, 02:38 PM   #271
ToxxicLuder90
Preludepower Member
"Spare"
lol
I knew i missed correcting some of them, & of course you found them.
No though i'm not moving the batt. box, im gonna have a full size spaIR sitting in there a lil odd. But it'll work & hopefully it'll look alright once the false floor is done.
__________________
-Brett-
91 Si 4ws-
97 SH ATTS-
Old 11-01-2007, 05:53 PM   #272
91_2.0_Si
iHeart iVTEC
91_2.0_Si's Avatar
91_2.0_Si is on a distinguished road
Send a message via AIM to 91_2.0_Si Send a message via Yahoo to 91_2.0_Si
you got any hubs left from your yellow lude?
fab up a bracket so you can mount the hub in the trunk, than you can have your spaRE nice and snug in the trunk.
__________________
-2003 VBP EP3
91_2.0_Si is offline   Reply With Quote
Old 11-01-2007, 10:47 PM   #273
ToxxicLuder90
Preludepower Member
I'll mount it so it still spins & all... spinnas in the trunk.
Ok that would be stupid, the spinning part that is.
The hub mounting idea, thats genius. I steal your idea. ... possibly
__________________
-Brett-
91 Si 4ws-
97 SH ATTS-
Old 11-02-2007, 01:06 PM   #274
ToxxicLuder90
Preludepower Member
I cant figure out this damn wiring issue.
I pulled the power wire all the way back out the back of the car.
When i test the batt. it says it still has charge.
Then i'll put the one end of the tester to a ground and the other end to the positive end thats usually connected to the distribution block up front... & i get the same numbers.
IM not really entirely sure which setting i should have the meter at but no matter which one i put it on it still comes up with the same #'s.
Am i doing something wrong cuz if it has charge all the way up then why the hell am i getting no power to accesories?
the other day when this happened i ended up clipping the pos. lead of a jump pack to the distribution block and neg. to the rad support... & it started but ran kinda odd.
Anyone wanna tell me which setting i should be using and maybe some other things to try checking.
I'd really appreciate it.
__________________
-Brett-
91 Si 4ws-
97 SH ATTS-
Old 11-02-2007, 03:34 PM   #275
ToxxicLuder90
Preludepower Member
nevermind crisis averted... it was just the stupid ass ground to the rear pan.
apparently i didnt have a good enough contact...even though it worked for the last month.
__________________
-Brett-
91 Si 4ws-
97 SH ATTS-
Reply
Bookmarks
  • Submit Thread to Digg Digg
  • Ads By Google
    Search Cloud
    2010 honda prelude 3rd gen prelude 4th gen prelude 5th gen prelude 5th generation prelude 6th gen prelude b21a1 car motivational posters convertible prelude dashboard paint edge2lyfe view profile floor jack reviews funny things to text your girlfriend h22 cams h22 manual tensioner conversion h22a4 h22a4 specs h23 vtec h23a vtec honda prelude 2010 honda prelude 5th gen how to text your girlfriend hp259 hp259 tire individual throttle bodies k1 attack for sale k20 prelude nice things to say to your girlfriend in a text nice things to text your girlfriend nitto neo gen reviews pcv valve symptoms power prelude prelude prelude convertible prelude forum prelude forums prelude power preludepower preludepower.com projector retrofit racing hart cp-035 rattle can paint job song suggester sweet things to say to your girlfriend in a text sweet things to say to your girlfriend over text sweet things to text your girlfriend things to text about things to text your girlfriend what to text your girlfriend www.preludepower.com
    Thread Tools
    Display Modes
    Posting Rules
    You may not post new threads
    You may not post replies
    You may not post attachments
    You may not edit your posts
    BB code is On
    Smilies are On
    [IMG] code is On
    HTML code is Off
    Forum Jump
    KickItBack = Cash Back
    Google
    vB.Sponsors
    PreludePower Forums
